01-22-2014, 03:44 PM
Warren, I too can't get anything on SW. I think we need to put an actual SW antenna for that to happen.
How well are you receiving AM and FM? Also, are both band relatively the same loudness? Since you replaced the caps, it wouldn't be bad practice to check measurments, but assuming the sound is clear with no chirps or distortion, I assume you have it properly recaped so far.
Have you changed the line capacitors?
Follow the technical manual, there's a 20-ish step verification that can be done, if you're all near their numbers, go straight ahead with aligment.
Still, uncertain about SW.
-Mars
