grid voltages
The reason G1 voltages aren't typically shown is that they will measure differently with different types of meters because of the loading effects.
One approach is to simply use the specs from a tube manual (or online tube data source) http://tdsl.duncanamps.com/ and you MUST use a meter with a high input resistance. Modern Digital meters or VTVMs generally fit the bill and they didn't have them back in those days.
Where there is a cathode resistor involved the cathode voltage will often tell the story but that requires that the tube be in good shape.
Could you describe your distortion a bit more? Normally neither of the 78s would account for that. Have you recapped the set ?
grid voltages - by DCASAZZA - 06-11-2008, 11:16 PM
[No subject] - by exray - 06-12-2008, 06:57 AM
There are currently 9182 online users. [Complete List]
» 3 Member(s) | 9179 Guest(s)
