Yes but its easier for me to just clip 2 wires of the meter. A scope is more accurate but not so much as to be noticed.
VTVM - by fields 100 - 01-22-2014, 08:44 PM
RE: VTVM - by tab10672 - 01-22-2014, 09:05 PM
RE: VTVM - by fields 100 - 01-22-2014, 09:18 PM
RE: VTVM - by morzh - 01-22-2014, 09:52 PM
RE: VTVM - by tab10672 - 01-22-2014, 11:40 PM
RE: VTVM - by Warren - 01-23-2014, 12:33 AM
RE: VTVM - by tab10672 - 01-23-2014, 12:37 AM
RE: VTVM - by Warren - 01-23-2014, 02:12 PM
RE: VTVM - by tab10672 - 01-23-2014, 02:23 PM
Eico 232 VTVM Schematic
There are currently 8818 online users. [Complete List]
» 1 Member(s) | 8817 Guest(s)
