Philco parts list
OOPS,
Brain fart,
Was refering to a zenith I am working on and posting on the other site as well.
Sorry,
But I still need the voltages on the electrolitics for the 118x.
One at a time I guess
Philco parts list - by murf - 01-23-2014, 09:41 PM
RE: Philco parts list - by morzh - 01-23-2014, 09:55 PM
RE: Philco parts list - by morzh - 01-23-2014, 10:28 PM
RE: Philco parts list - by murf - 01-23-2014, 11:00 PM
RE: Philco parts list - by morzh - 01-24-2014, 12:28 AM
RE: Philco parts list - by murf - 01-24-2014, 07:51 AM
Philco 91 Tuning Condenser
There are currently 9822 online users. [Complete List]
» 1 Member(s) | 9821 Guest(s)
