PHILCO 41-608 ADJUSTMENTS
Thanks Randy. I have tried adjusting it and get no change in intensity. I am going to pull out the chassis and take a look for a broken wire, or clean it as you mentioned. I have the "table top record player" from 1941 that I just restored, and it has the adjustment on the back of the chassis (which is where it should be), and it adjusts just fine, and I get no microphonics. As for the 41-608, I think it is too bright and that is why I cannot turn it up too high. I need to syncronize the volume between the radio and record player better.
PHILCO 41-608 ADJUSTMENTS - by davidff - 02-06-2012, 09:50 AM
RE: PHILCO 41-608 ADJUSTMENTS - by Randy H. - 01-23-2014, 07:33 PM
RE: PHILCO 41-608 ADJUSTMENTS - by davidff - 01-24-2014, 11:22 AM
RE: PHILCO 41-608 ADJUSTMENTS - by sam - 01-24-2014, 11:49 AM
RE: PHILCO 41-608 ADJUSTMENTS - by Randy H. - 01-24-2014, 03:23 PM
RE: PHILCO 41-608 ADJUSTMENTS - by davidff - 01-27-2014, 12:31 PM
RE: PHILCO 41-608 ADJUSTMENTS - by Randy H. - 01-27-2014, 01:54 PM
RE: PHILCO 41-608 ADJUSTMENTS - by davidff - 01-27-2014, 02:54 PM
Philco 91 Tuning Condenser
