New Flea Market found and Philcos!
Sadly, that flea market folded and closed the middle of last year. Mostly because of a state bridge project that dragged on for nearly a year. The detours took possible customers completely around where the flea market was at and business dropped completely, killing it. Icon_sad
New Flea Market found and Philcos! - by Jayce - 09-08-2012, 08:17 PM
RE: New Flea Market found and Philcos! - by Jayce - 09-08-2012, 09:06 PM
RE: New Flea Market found and Philcos! - by Jayce - 09-10-2012, 07:30 PM
RE: New Flea Market found and Philcos! - by gregb - 01-24-2014, 02:08 PM
RE: New Flea Market found and Philcos! - by Jayce - 01-24-2014, 03:40 PM
RE: New Flea Market found and Philcos! - by Jayce - 01-26-2014, 08:01 PM
RE: New Flea Market found and Philcos! - by Arran - 01-27-2014, 10:28 PM
RE: New Flea Market found and Philcos! - by Jayce - 01-28-2014, 12:23 AM
RE: New Flea Market found and Philcos! - by Arran - 01-28-2014, 04:26 AM
RE: New Flea Market found and Philcos! - by Jamie - 01-28-2014, 05:07 PM
Philco 91 Tuning Condenser
