Predicta Tandem / Penthouse scored
After several frustrating days, I discovered there is an error in the Sams service info tube chart! I had the tuner tubes flip=flopped. With them in their correct sockets, the et sprang to life Icon_biggrin
[Image: http://farm8.staticflickr.com/7423/11903...baaa_c.jpg]
That was so much fun, I dove right into restoring a second identical chassis.
[Image: http://farm8.staticflickr.com/7392/11956...f7ce_c.jpg]
RE: Predicta Tandem / Penthouse scored - by w4rtc - 03-28-2012, 06:38 PM
RE: Predicta Tandem / Penthouse scored - by w4rtc - 05-08-2012, 04:32 PM
RE: Predicta Tandem / Penthouse scored - by jontz - 01-10-2014, 08:19 AM
RE: Predicta Tandem / Penthouse scored - by Bob Andersen - 01-24-2014, 07:06 PM
RE: Predicta Tandem / Penthouse scored - by gregb - 01-24-2014, 07:40 PM
RE: Predicta Tandem / Penthouse scored - by w4rtc - 01-24-2014, 10:21 PM
RE: Predicta Tandem / Penthouse scored - by gregb - 01-24-2014, 10:22 PM
RE: Predicta Tandem / Penthouse scored - by morzh - 02-01-2014, 12:31 AM
RE: Predicta Tandem / Penthouse scored - by rlr - 10-21-2017, 10:41 AM
