replacing a dual Ecap with 2
When replacing the cord, use one with a larger blade (which is neutral). Connect neutral to the ground side of the circuit
what is a cord? and what is a blade?? <---new guy here
schematic is above
replacing a dual Ecap with 2 - by OldRestorer - 01-24-2014, 09:39 PM
RE: replacing a dual Ecap with 2 - by gregb - 01-24-2014, 09:53 PM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-24-2014, 10:03 PM
RE: replacing a dual Ecap with 2 - by skyscraper - 01-24-2014, 10:12 PM
RE: replacing a dual Ecap with 2 - by klondike98 - 01-24-2014, 10:16 PM
RE: replacing a dual Ecap with 2 - by skyscraper - 01-24-2014, 10:24 PM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-24-2014, 10:26 PM
RE: replacing a dual Ecap with 2 - by gregb - 01-24-2014, 10:35 PM
RE: replacing a dual Ecap with 2 - by skyscraper - 01-24-2014, 10:39 PM
RE: replacing a dual Ecap with 2 - by gregb - 01-24-2014, 10:40 PM
RE: replacing a dual Ecap with 2 - by morzh - 01-24-2014, 10:58 PM
RE: replacing a dual Ecap with 2 - by Joe Rossi - 01-25-2014, 08:16 AM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-25-2014, 08:18 AM
RE: replacing a dual Ecap with 2 - by skyscraper - 01-25-2014, 10:35 AM
RE: replacing a dual Ecap with 2 - by gregb - 01-25-2014, 12:18 PM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-26-2014, 08:01 AM
RE: replacing a dual Ecap with 2 - by Ron Ramirez - 01-26-2014, 10:05 AM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-26-2014, 10:13 AM
RE: replacing a dual Ecap with 2 - by skyscraper - 01-26-2014, 10:51 AM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-26-2014, 11:10 AM
RE: replacing a dual Ecap with 2 - by gregb - 01-26-2014, 11:26 AM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-26-2014, 01:12 PM
RE: replacing a dual Ecap with 2 - by skyscraper - 01-26-2014, 01:57 PM
RE: replacing a dual Ecap with 2 - by klondike98 - 01-26-2014, 02:05 PM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-26-2014, 03:30 PM
RE: replacing a dual Ecap with 2 - by skyscraper - 01-26-2014, 08:32 PM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-27-2014, 09:54 AM
RE: replacing a dual Ecap with 2 - by gregb - 01-27-2014, 10:09 AM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-27-2014, 11:16 AM
RE: replacing a dual Ecap with 2 - by OldRestorer - 01-27-2014, 01:44 PM
RE: replacing a dual Ecap with 2 - by gregb - 01-27-2014, 01:56 PM
RE: replacing a dual Ecap with 2 - by OldRestorer - 02-05-2014, 08:11 AM
RE: replacing a dual Ecap with 2 - by gregb - 02-05-2014, 11:53 AM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4007 online users. [Complete List]
» 2 Member(s) | 4005 Guest(s)
