  • 1 Vote(s) - 5 Average
reproduction knobs
this photo shows the detail on a small rosette the color isn't right but I just poured it with left over mixture the closest one is the repro
the entire reproduction set installed on my 89
reproduction knobs - by tab10672 - 01-24-2014, 10:43 PM
RE: reproduction knobs - by morzh - 01-24-2014, 10:48 PM
RE: reproduction knobs - by tab10672 - 01-24-2014, 10:53 PM
RE: reproduction knobs - by tab10672 - 01-24-2014, 10:58 PM
RE: reproduction knobs - by skyscraper - 01-24-2014, 10:59 PM
RE: reproduction knobs - by tab10672 - 01-24-2014, 11:03 PM
RE: reproduction knobs - by Jayce - 01-24-2014, 11:48 PM
RE: reproduction knobs - by Bob Andersen - 01-25-2014, 01:31 AM
RE: reproduction knobs - by OldRestorer - 01-25-2014, 08:07 AM
RE: reproduction knobs - by tab10672 - 01-25-2014, 02:16 PM
RE: reproduction knobs - by jerryhawthorne - 01-25-2014, 02:59 PM
RE: reproduction knobs - by Warren - 01-25-2014, 03:07 PM
RE: reproduction knobs - by tab10672 - 01-25-2014, 03:16 PM
RE: reproduction knobs - by Jamie - 01-25-2014, 05:04 PM
Philco 91 Tuning Condenser
There are currently 10395 online users. [Complete List]
» 2 Member(s) | 10393 Guest(s)
