  • 1 Vote(s) - 5 Average
reproduction knobs
Hobby lobby sells a variety of plastic mix, they even have crystal clear for knobs like on the sundial radios. The mix I have very closely resembles bakelite, you can even marble the color by lightly mixing/swirling the dye in last and when you have the dye mixed right you absolutely cannot tell which is the reproduction "unless you look at the shaft end"
reproduction knobs - by tab10672 - 01-24-2014, 10:43 PM
RE: reproduction knobs - by morzh - 01-24-2014, 10:48 PM
RE: reproduction knobs - by tab10672 - 01-24-2014, 10:53 PM
RE: reproduction knobs - by tab10672 - 01-24-2014, 10:58 PM
RE: reproduction knobs - by skyscraper - 01-24-2014, 10:59 PM
RE: reproduction knobs - by tab10672 - 01-24-2014, 11:03 PM
RE: reproduction knobs - by Jayce - 01-24-2014, 11:48 PM
RE: reproduction knobs - by Bob Andersen - 01-25-2014, 01:31 AM
RE: reproduction knobs - by OldRestorer - 01-25-2014, 08:07 AM
RE: reproduction knobs - by tab10672 - 01-25-2014, 02:16 PM
RE: reproduction knobs - by jerryhawthorne - 01-25-2014, 02:59 PM
RE: reproduction knobs - by Warren - 01-25-2014, 03:07 PM
RE: reproduction knobs - by tab10672 - 01-25-2014, 03:16 PM
RE: reproduction knobs - by Jamie - 01-25-2014, 05:04 PM
Philco 91 Tuning Condenser
There are currently 8501 online users. [Complete List]
» 2 Member(s) | 8499 Guest(s)
