Need a decent schematic Scott Laureate
Brenda
Are you aware of this site?
http://ehscott.ning.com/
They not only have their own forum and photo gallery, but also schematics/service info.
RE: Need a decent schematic Scott Laureate - by Ron Ramirez - 01-25-2014, 07:43 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3615 online users. [Complete List]
» 1 Member(s) | 3614 Guest(s)
