Unusual Audio Output Circuit
As far as I know, the 37-650 was the first Philco model to use that goofy phase inversion. I too, couldn't figure out how Philco got inversion. I was in my first year of high school, and a smarter kid than I, explained it.
The "screen inverter" was used by Philco for loads of sets for all of those years. I'm currerntly working on a '39 Packard-Philco set with P-P 41 tubes, and there it is; our favorite phase inverter!
I must say that for all of the years that our family had the 37-650 that father bought new for Chistmas 1936, the set worked perfectly, and sounded very good to all of us. Today, the sound system in my living room is a tad more sophisticated, but what might one expect?
Also, as far as I know, Hazeltine Corporation did Philco's circuit engineering, so I suspect that this inverter is one of their wrinkles. You have to admit...it's tricky, but it works!
Unusual Audio Output Circuit - by Joeztech - 01-12-2014, 10:13 AM
RE: Unusual Audio Output Circuit - by codefox1 - 01-12-2014, 06:48 PM
RE: Unusual Audio Output Circuit - by Joeztech - 01-12-2014, 07:39 PM
RE: Unusual Audio Output Circuit - by BrendaAnnD - 01-12-2014, 11:31 PM
RE: Unusual Audio Output Circuit - by Arran - 01-13-2014, 12:28 AM
RE: Unusual Audio Output Circuit - by hsusmann - 01-13-2014, 04:21 PM
RE: Unusual Audio Output Circuit - by Doug Houston - 01-26-2014, 03:38 PM
RE: Unusual Audio Output Circuit - by hsusmann - 01-26-2014, 03:50 PM
RE: Unusual Audio Output Circuit - by Randy H. - 01-26-2014, 07:41 PM
RE: Unusual Audio Output Circuit - by Joeztech - 01-27-2014, 07:44 AM
RE: Unusual Audio Output Circuit - by Radioroslyn - 01-27-2014, 08:12 AM
RE: Unusual Audio Output Circuit - by codefox1 - 02-02-2014, 08:42 PM
There are currently 9176 online users. [Complete List]
» 2 Member(s) | 9174 Guest(s)
