Philco table top
I have a mid to late 30's Stromberg-Carlson with a shrunken plastic face piece. I wondered how it ever got that way. Sounds like it is made of Tenite then from what I just read.
Mine is not warped, it is just too small now for the cutout in the cabinet!
Herb S.
Ithaca NY
Philco table top - by fields 100 - 01-26-2014, 08:36 AM
RE: Philco table top - by Ron Ramirez - 01-26-2014, 09:53 AM
RE: Philco table top - by hsusmann - 01-26-2014, 04:04 PM
RE: Philco table top - by TimC - 01-28-2014, 06:48 PM
RE: Philco table top - by hsusmann - 01-28-2014, 08:33 PM
There are currently 10876 online users. [Complete List]
» 2 Member(s) | 10874 Guest(s)
