dogbone resistor value
This may seem like a dumb question for all you Philco techs, but here goes anyway.
Working on a Philco model 118 code 121 chassis and noticed a large dogbone resistor that has a couple hot spots(bubbled).
It is a large dogbone, I am guessing at least 3 watt,with an orange body and red end. No dot in the center.
The schematics does not show this resistor, so I will just replace it with a new one if I can figure out what it is.
Checks about 46.9 k ohms.
Thanks guy's,
murf
dogbone resistor value - by murf - 01-26-2014, 06:29 PM
RE: dogbone resistor value - by Randy H. - 01-26-2014, 07:04 PM
RE: dogbone resistor value - by John R - 01-26-2014, 07:11 PM
RE: dogbone resistor value - by murf - 01-26-2014, 07:22 PM
RE: dogbone resistor value - by tab10672 - 01-26-2014, 08:43 PM
Philco 91 Tuning Condenser
There are currently 8912 online users. [Complete List]
» 3 Member(s) | 8909 Guest(s)
