Philco 37-675 for $50
I guess as with many of the 37 models you could get this one with the shadow meter or without and this one is without (magnetic tuning). It really appears to be a lot like my 38-1 with PP 6F6's with a 6F6 driver so the output should be 12-15 watts. It has 2 IF stages so it should have decent performance, I have someone that is willing to wrap it up and toss it on a greyhound bus so that covers the shipping issue. For the price with shipping I might have ~100-120 into this radio so that isn't too bad. Actually it is probably a better performer than the 38-1, when I went back I noticed the 38-1 doesn't have a 2nd IF and rather than using a 6J5 as an inverter feeding a 6F6 driver to the PP 6F6 outputs the 38-1 using a 6J5 inverter feeding two 6J5 drivers to the PP 6F6 outputs sucking up one extra tube for the same result.
PhilcoBenz, more than likely the $275 was a typo and it should have been $175. Normally there was about $15-25 difference between the standard and Deluxe model in 37 so I think the price was more like $175. The one nice thing is that the Deluxe model was the less produced model of the two types with the standard being over triple the total of the Deluxe.
Philco 37-675 for $50 - by 49Stude63 - 06-15-2008, 10:26 PM
[No subject] - by Ron Ramirez - 06-15-2008, 10:45 PM
[No subject] - by philcobenz - 06-15-2008, 10:47 PM
[No subject] - by 49Stude63 - 06-15-2008, 10:48 PM
[No subject] - by BDM - 06-15-2008, 11:39 PM
[No subject] - by 49Stude63 - 06-16-2008, 11:14 AM
[No subject] - by Sean - 06-17-2008, 09:26 AM
Is your power supply adequate? Perhaps it cannot source the current required. Or...bad transistors.morzh — 09:32 AM
Hi R3, just glancing over the schematic,if C1 and C2 are good and they appear to be by the voltage you are getting on TP...462ron — 08:28 AM
42-345 Resistors
Those wax-paper caps, if they have not already failed, are very likely to fail, and the same is true of the old electrol...DaleHCook — 06:48 AM
What make and model of power supply are you using? Is it regulated? Have you tried measuring the current drawn by the ra...DaleHCook — 06:43 AM
Ooh, backlighting will be a nice addition! I’ve got a 70’s model GE clock (not the kind with the numerals on cards that ...jrblasde — 12:26 AM
Hello Joseph, You have been really busy on this set it really puts me to shame !! Great job so far I finished up my 1...radiorich — 12:08 AM
One radio, check. I connected the power wire to 12.2v. I measured all of the voltage on the wires on the potentiometer...R3Sons — 11:53 PM
Good evening, folks! I guess I’ll provide an update on this week’s progress. I am awaiting one last order from Mouser, w...jrblasde — 11:41 PM
OK, experience with electronics helps. What do you mean by " draw 5-7 volts"? Amps are drawn, Volts are ap...morzh — 09:43 PM
Sorry, point 19 was 10vR3Sons — 09:11 PM
There are currently 1877 online users. [Complete List]
» 3 Member(s) | 1874 Guest(s)
