1941 Philco push button on/off switches
Thought I'd revive this thread to add some pics of a RS switch installation. Didn't use solder or JB weld, like Ron. The installation with the nut and lockwasher seems secure. This is a 41-250 but they all look the same to me.
[Image: http://i202.photobucket.com/albums/aa75/...oremod.jpg]
[Image: http://i202.photobucket.com/albums/aa75/.../onbar.jpg]
[Image: http://i202.photobucket.com/albums/aa75/...nrack2.jpg]
[Image: http://i202.photobucket.com/albums/aa75/...talled.jpg]
[No subject] - by Ron Ramirez - 11-22-2005, 12:50 AM
[No subject] - by Bill Hutchinson - 11-22-2005, 08:05 PM
Success! - by Raleigh - 06-13-2007, 06:23 PM
[No subject] - by rickd - 06-16-2008, 03:22 PM
[No subject] - by Chuck Schwark - 06-16-2008, 04:08 PM
[No subject] - by rickd - 06-16-2008, 05:07 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
