New Flea Market found and Philcos!
Jayce,
Isn't THAT just nice? Here in Tucson they have been 'renovating' the Downtown area for about 10 years. Lots of lost busineses. On the North side they widened a road for so long, and tied up an intersection for so long that about 7 businesses went out in one center alone. You could not get in. And they didn't care!
New Flea Market found and Philcos! - by Jayce - 09-08-2012, 08:17 PM
RE: New Flea Market found and Philcos! - by Jayce - 09-08-2012, 09:06 PM
RE: New Flea Market found and Philcos! - by Jayce - 09-10-2012, 07:30 PM
RE: New Flea Market found and Philcos! - by gregb - 01-24-2014, 02:08 PM
RE: New Flea Market found and Philcos! - by Jayce - 01-24-2014, 03:40 PM
RE: New Flea Market found and Philcos! - by Randy H. - 01-26-2014, 07:56 PM
RE: New Flea Market found and Philcos! - by Jayce - 01-26-2014, 08:01 PM
RE: New Flea Market found and Philcos! - by Arran - 01-27-2014, 10:28 PM
RE: New Flea Market found and Philcos! - by Jayce - 01-28-2014, 12:23 AM
RE: New Flea Market found and Philcos! - by Arran - 01-28-2014, 04:26 AM
RE: New Flea Market found and Philcos! - by Jamie - 01-28-2014, 05:07 PM
Philco 91 Tuning Condenser
