Philco Phonographs.
For what it's worth, I believe the FIRST one they made themselves was the one in the '42 combo with the Beam-O-Light and the bakelite arm.
Philco Phonographs. - by Jayce - 01-19-2014, 06:50 PM
RE: Philco Phonographs. - by Don Lind - 01-21-2014, 03:41 PM
RE: Philco Phonographs. - by Jayce - 01-22-2014, 05:38 PM
RE: Philco Phonographs. - by Randy H. - 01-26-2014, 08:01 PM
Philco 91 Tuning Condenser
There are currently 10064 online users. [Complete List]
» 1 Member(s) | 10063 Guest(s)
