58th birthday present.
Just an update. Managed to get all the tubes I needed for the 95 finally and gave it a quick test after doing a thorough visual inspection of the chassis, wires etc. it works great and receives many station across the dial. Cool.
58th birthday present. - by Groundhog74 - 11-17-2013, 10:45 PM
RE: 58th birthday present. - by Arran - 11-18-2013, 01:47 AM
RE: 58th birthday present. - by TA Forbes - 11-18-2013, 03:15 AM
RE: 58th birthday present. - by PhilcoJohn - 11-18-2013, 09:47 AM
RE: 58th birthday present. - by Groundhog74 - 11-18-2013, 09:57 AM
RE: 58th birthday present. - by Gene Pederson - 11-18-2013, 05:54 PM
RE: 58th birthday present. - by GarySP - 11-18-2013, 07:19 PM
RE: 58th birthday present. - by Groundhog74 - 01-26-2014, 08:39 PM
RE: 58th birthday present. - by morzh - 01-26-2014, 09:22 PM
RE: 58th birthday present. - by PAradiogeek - 01-26-2014, 10:31 PM
There are currently 8564 online users. [Complete List]
» 1 Member(s) | 8563 Guest(s)
