dogbone resistor value
B.E.D. Body, end, dot. just in case you run into another one, if there is no dot then it would be the same color as the body. If the body is orange without a dot then the dot is orange also.
dogbone resistor value - by murf - 01-26-2014, 06:29 PM
RE: dogbone resistor value - by Randy H. - 01-26-2014, 07:04 PM
RE: dogbone resistor value - by John R - 01-26-2014, 07:11 PM
RE: dogbone resistor value - by murf - 01-26-2014, 07:22 PM
RE: dogbone resistor value - by tab10672 - 01-26-2014, 08:43 PM
Philco 91 Tuning Condenser
There are currently 6867 online users. [Complete List]
» 2 Member(s) | 6865 Guest(s)
