Philco 1942 radio
Also beware of rubber coated wire. I have heard that this is the vintage where they used it and now it is all brittle and crumbly.
Philco 1942 radio - by Mike Gessner - 01-27-2014, 02:18 AM
RE: Philco 1942 radio - by OldRestorer - 01-27-2014, 07:46 AM
RE: Philco 1942 radio - by Radioroslyn - 01-27-2014, 08:15 AM
RE: Philco 1942 radio - by hsusmann - 01-27-2014, 08:57 AM
RE: Philco 1942 radio - by morzh - 01-27-2014, 11:34 AM
RE: Philco 1942 radio - by klondike98 - 01-27-2014, 11:53 AM
RE: Philco 1942 radio - by exray - 01-27-2014, 07:07 PM
RE: Philco 1942 radio - by Mike Gessner - 01-27-2014, 07:42 PM
RE: Philco 1942 radio - by Arran - 01-27-2014, 10:12 PM
RE: Philco 1942 radio - by Raleigh - 01-27-2014, 11:14 PM
Philco 91 Tuning Condenser
There are currently 10070 online users. [Complete List]
» 1 Member(s) | 10069 Guest(s)
