PHILCO 41-608 ADJUSTMENTS
I'd like that! Thanks. Where do you get your flocking material? I have at least two TT's that need it. The direct drive feature is GOOD, and even better for those of us who want to restore old phonos. Rubber pucks are SO hard to find!!! Especially in the correct configurations.
PHILCO 41-608 ADJUSTMENTS - by davidff - 02-06-2012, 09:50 AM
RE: PHILCO 41-608 ADJUSTMENTS - by Randy H. - 01-23-2014, 07:33 PM
RE: PHILCO 41-608 ADJUSTMENTS - by davidff - 01-24-2014, 11:22 AM
RE: PHILCO 41-608 ADJUSTMENTS - by sam - 01-24-2014, 11:49 AM
RE: PHILCO 41-608 ADJUSTMENTS - by Randy H. - 01-24-2014, 03:23 PM
RE: PHILCO 41-608 ADJUSTMENTS - by davidff - 01-27-2014, 12:31 PM
RE: PHILCO 41-608 ADJUSTMENTS - by Randy H. - 01-27-2014, 01:54 PM
RE: PHILCO 41-608 ADJUSTMENTS - by davidff - 01-27-2014, 02:54 PM
Philco 91 Tuning Condenser
