Quick Question about a Schematic..
Actually the sch shows a speaker WITH hum bucking coil.
Good time to check if it is present in the real speaker.
As for the RC I am not sure it is a resonant trap (or do you mean a snubber?) and whether this kins of things would be effective. It might be simply letting some of the ripple in counter-phase (one goes through inductance, one through a cap) so when they combine at the output transformer's pin they cancel each other.
For a snubber to work here.....something has to resonate.
Quick Question about a Schematic.. - by Jamie - 01-25-2014, 08:12 PM
RE: Quick Question about a Schematic.. - by morzh - 01-25-2014, 08:16 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-25-2014, 08:36 PM
RE: Quick Question about a Schematic.. - by gregb - 01-25-2014, 08:41 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-25-2014, 08:54 PM
RE: Quick Question about a Schematic.. - by morzh - 01-26-2014, 09:28 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-27-2014, 12:45 PM
RE: Quick Question about a Schematic.. - by morzh - 01-27-2014, 12:57 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-27-2014, 01:19 PM
RE: Quick Question about a Schematic.. - by morzh - 01-27-2014, 02:50 PM
RE: Quick Question about a Schematic.. - by morzh - 01-27-2014, 03:00 PM
RE: Quick Question about a Schematic.. - by morzh - 01-27-2014, 03:31 PM
RE: Quick Question about a Schematic.. - by morzh - 01-27-2014, 04:50 PM
RE: Quick Question about a Schematic.. - by morzh - 01-27-2014, 05:54 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-27-2014, 06:59 PM
RE: Quick Question about a Schematic.. - by morzh - 01-27-2014, 11:48 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 10:45 AM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 10:47 AM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 11:06 AM
RE: Quick Question about a Schematic.. - by gregb - 01-28-2014, 11:07 AM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 11:15 AM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 11:19 AM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 11:25 AM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 11:30 AM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 11:43 AM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 12:09 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 12:14 PM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 12:15 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 12:34 PM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 12:39 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 12:40 PM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 02:34 PM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 02:37 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 02:39 PM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 02:47 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 02:57 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 03:10 PM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 03:17 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 03:32 PM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 03:57 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 04:13 PM
RE: Quick Question about a Schematic.. - by morzh - 01-28-2014, 04:19 PM
RE: Quick Question about a Schematic.. - by Jamie - 01-28-2014, 04:23 PM
Philco 91 Tuning Condenser
There are currently 10082 online users. [Complete List]
» 1 Member(s) | 10081 Guest(s)
