Aligning 40-155...signal bleeding in
Thank you Terry and John.
I will hook the loop back up and see how we do.
Yes John pretty much the same as the 150 I believe just minus one tube.
RE: Aligning 40-155...signal bleeding in - by jeffgniffke - 01-27-2014, 05:05 PM
There are currently 3886 online users. [Complete List]
» 1 Member(s) | 3885 Guest(s)
