Philco 513- to restore or not to restore
Post a picture Kevin! If it was me I would most likely restore it and go about getting that original speaker fixed up as original. There has to be a good one around with a bad cabinet, a little searching would yield something I am sure. Do a real good restuff/ hidem restore so it looks unrestored.
What ever you do its yours and enjoy it!
Gregb
RE: Philco 513- to restore or not to restore - by gregb - 01-28-2014, 10:38 PM
There are currently 9941 online users. [Complete List]
» 3 Member(s) | 9938 Guest(s)
