Philco 513- to restore or not to restore
Unfortunately, from what I understand, finding a usable speaker of this type is next to impossible. they use old style pot metal which warps and cracks. The method for restoring is to use a modern permanent magnet speaker with a impedance matching transformer, which will actually make this radio sound better as the original speaker was already dated when used. I do have a speaker shell for a 511 which I could put the original speaker guts into just to keep them.
Here are some pics of my 513.
[Image: http://i1160.photobucket.com/albums/q500...e08b46.jpg]
[Image: http://i1160.photobucket.com/albums/q500...a21f1c.jpg]
RE: Philco 513- to restore or not to restore - by 37silverstreak - 01-28-2014, 11:15 PM
Philco 91 Tuning Condenser
There are currently 5721 online users. [Complete List]
» 2 Member(s) | 5719 Guest(s)
