  • 1 Vote(s) - 5 Average
GE 212 FM Antenna
Remember one thing. When you use the line cord for an antenna, that the line cord then needs to be positioned to pick up the best signal. This always made me crazy, since your house wiring also becomes part of it, so sometimes the cord needs to run at odd angles from the radio.
Also, for FM frequencies, 100pf is MUCH too large. 2 to 5pf is more like it.
GE 212 FM Antenna - by Raleigh - 01-28-2014, 01:21 PM
RE: GE 212 FM Antenna - by morzh - 01-28-2014, 02:40 PM
RE: GE 212 FM Antenna - by Raleigh - 01-28-2014, 03:25 PM
RE: GE 212 FM Antenna - by skyscraper - 01-28-2014, 04:26 PM
RE: GE 212 FM Antenna - by BrendaAnnD - 01-28-2014, 09:15 PM
RE: GE 212 FM Antenna - by Raleigh - 01-29-2014, 01:11 AM
RE: GE 212 FM Antenna - by BrendaAnnD - 01-29-2014, 01:28 AM
RE: GE 212 FM Antenna - by Ron Ramirez - 01-29-2014, 09:32 AM
RE: GE 212 FM Antenna - by Raleigh - 01-29-2014, 12:21 PM
RE: GE 212 FM Antenna - by Ron Ramirez - 01-29-2014, 12:28 PM
RE: GE 212 FM Antenna - by Mondial - 01-29-2014, 04:33 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
