  • 1 Vote(s) - 5 Average
GE 212 FM Antenna
Philco used a small flat piece of metal clamped around the power cord, well insulated, as an FM antenna on many of their postwar FM radios. Sounds similar to the GE setup.
GE 212 FM Antenna - by Raleigh - 01-28-2014, 01:21 PM
RE: GE 212 FM Antenna - by morzh - 01-28-2014, 02:40 PM
RE: GE 212 FM Antenna - by Raleigh - 01-28-2014, 03:25 PM
RE: GE 212 FM Antenna - by skyscraper - 01-28-2014, 04:26 PM
RE: GE 212 FM Antenna - by BrendaAnnD - 01-28-2014, 09:15 PM
RE: GE 212 FM Antenna - by Raleigh - 01-29-2014, 01:11 AM
RE: GE 212 FM Antenna - by BrendaAnnD - 01-29-2014, 01:28 AM
RE: GE 212 FM Antenna - by Ron Ramirez - 01-29-2014, 09:32 AM
RE: GE 212 FM Antenna - by Raleigh - 01-29-2014, 12:21 PM
RE: GE 212 FM Antenna - by Ron Ramirez - 01-29-2014, 12:28 PM
RE: GE 212 FM Antenna - by Mondial - 01-29-2014, 04:33 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
