  • 2 Vote(s) - 3 Average
Pilot H220 Radio @ Flea Market
Well, the Stromberg I restored is exactly that. The chassis is RF, the GND is direct AC plug pin.
They are still connected via 0.2uF cap which makes the chassis kinda hot. But formally it is considered floating.
The Emerson was real hot chassis - both RF and the rectifier negative are an AC plug pin.
Pilot H220 Radio @ Flea Market - by VntgRads - 01-26-2014, 02:36 PM
RE: Pilot H220 Radio @ Flea Market - by jontz - 01-26-2014, 02:37 PM
RE: Pilot H220 Radio @ Flea Market - by VntgRads - 01-26-2014, 02:38 PM
RE: Pilot H220 Radio @ Flea Market - by hsusmann - 01-26-2014, 04:09 PM
RE: Pilot H220 Radio @ Flea Market - by Jayce - 01-26-2014, 08:05 PM
RE: Pilot H220 Radio @ Flea Market - by Joe Rossi - 01-28-2014, 12:51 PM
RE: Pilot H220 Radio @ Flea Market - by morzh - 01-28-2014, 02:44 PM
RE: Pilot H220 Radio @ Flea Market - by morzh - 01-29-2014, 10:41 AM
RE: Pilot H220 Radio @ Flea Market - by Arran - 01-30-2014, 01:26 AM
RE: Pilot H220 Radio @ Flea Market - by VntgRads - 01-30-2014, 01:44 AM
RE: Pilot H220 Radio @ Flea Market - by Arran - 01-30-2014, 02:22 AM
RE: Pilot H220 Radio @ Flea Market - by VntgRads - 01-30-2014, 02:27 AM
RE: Pilot H220 Radio @ Flea Market - by VntgRads - 01-30-2014, 03:37 AM
RE: Pilot H220 Radio @ Flea Market - by TA Forbes - 01-30-2014, 10:17 AM
RE: Pilot H220 Radio @ Flea Market - by joybird - 03-03-2014, 07:15 PM
RE: Pilot H220 Radio @ Flea Market - by TA Forbes - 03-04-2014, 12:01 AM
RE: Pilot H220 Radio @ Flea Market - by TA Forbes - 03-04-2014, 12:03 AM
RE: Pilot H220 Radio @ Flea Market - by joybird - 03-04-2014, 08:47 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
