Books on restoring Tube Radios
A book titled as "AA5" will probably have, well, AA5s in it. And with AA5, you restored one (OK, two) of them - you pretty much know them all. Even those made in Latvia (can I still call them AA5 or should I go like AL5?).
Somehow I think there are not tons of those out there, and if you look at two or three and look at reviews (and solicit opinions) you will know what you need.
Books on restoring Tube Radios - by Warren - 01-29-2014, 03:04 PM
RE: Books on restoring Tube Radios - by morzh - 01-29-2014, 03:09 PM
RE: Books on restoring Tube Radios - by Warren - 01-29-2014, 04:41 PM
RE: Books on restoring Tube Radios - by Raleigh - 01-29-2014, 05:26 PM
RE: Books on restoring Tube Radios - by Warren - 01-29-2014, 06:54 PM
Philco 91 Tuning Condenser
There are currently 9388 online users. [Complete List]
» 1 Member(s) | 9387 Guest(s)
