Zenith Speaker Problem
A new speaker is usually cheaper than a full re-coning. Plus shipping. Both ways. Unless done by yourself. If you know how. And have the cone.
Zenith Speaker Problem - by Jayce - 01-29-2014, 05:53 PM
RE: Zenith Speaker Problem - by morzh - 01-29-2014, 06:29 PM
RE: Zenith Speaker Problem - by Arran - 01-30-2014, 01:35 AM
RE: Zenith Speaker Problem - by Jayce - 01-30-2014, 12:12 PM
RE: Zenith Speaker Problem - by Richmond Designs - 01-30-2014, 10:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
