grill cloth for a 45 butterfly
I am in need of the correct grill cloth for my 45. I have the original but It may need replacing. Does anyone know which one is the closest match?
looked all over ebay and didn't see anything except this.
http://www.ebay.com/itm/141170556356?_tr...EBIDX%3AIT
Anyone know?
grill cloth for a 45 butterfly - by OldRestorer - 01-29-2014, 10:07 PM
RE: grill cloth for a 45 butterfly - by morzh - 01-31-2014, 10:34 AM
RE: grill cloth for a 45 butterfly - by tab10672 - 01-31-2014, 08:14 PM
Philco 91 Tuning Condenser
There are currently 8402 online users. [Complete List]
» 2 Member(s) | 8400 Guest(s)
