A few Craigslist finds
Love the 38-7. I had a chairside and it sounded great
A few Craigslist finds - by skyscraper - 01-30-2014, 04:22 PM
RE: A few Craigslist finds - by OldRestorer - 01-30-2014, 04:28 PM
RE: A few Craigslist finds - by skyscraper - 01-30-2014, 05:05 PM
RE: A few Craigslist finds - by TimC - 01-30-2014, 07:39 PM
RE: A few Craigslist finds - by tab10672 - 01-30-2014, 08:04 PM
RE: A few Craigslist finds - by skyscraper - 01-30-2014, 08:37 PM
RE: A few Craigslist finds - by Paul Philco322 - 01-30-2014, 09:03 PM
RE: A few Craigslist finds - by Eric T - 02-03-2014, 08:06 AM
RE: A few Craigslist finds - by TA Forbes - 02-03-2014, 12:00 PM
Philco 91 Tuning Condenser
There are currently 10137 online users. [Complete List]
» 3 Member(s) | 10134 Guest(s)
