Help with identifying model number
Arran is correct - 53-960, the only Tropic-style radio that was sold in the USA rather than being sold as an export model.
http://www.philcoradio.com/gallery/1953.htm#ab
Interesting, by 1953 Philco (USA) was no longer producing Tropics for export; they had turned that over to their UK and Argentina subsidiaries by then.
Help with identifying model number - by michombre - 01-30-2014, 09:04 PM
RE: Help with identifying model number - by Arran - 01-30-2014, 09:18 PM
RE: Help with identifying model number - by Ron Ramirez - 01-31-2014, 06:38 AM
