Don found a Philco 16B Tombstone
Hey Ron we've got some old vintage cloth that we are going to put in very soon and it will look great. I'll take some pictures of the chassis Monday and post them.
Don found a Philco 16B Tombstone - by Ronin61 - 01-29-2014, 05:09 PM
RE: Don found a Philco 16B Tombstone - by morzh - 01-29-2014, 05:48 PM
RE: Don found a Philco 16B Tombstone - by Ronin61 - 01-29-2014, 09:20 PM
RE: Don found a Philco 16B Tombstone - by morzh - 01-29-2014, 11:17 PM
RE: Don found a Philco 16B Tombstone - by Ronin61 - 01-31-2014, 04:38 PM
RE: Don found a Philco 16B Tombstone - by Ronin61 - 02-04-2014, 01:21 AM
Philco 91 Tuning Condenser
There are currently 9403 online users. [Complete List]
» 1 Member(s) | 9402 Guest(s)
