Don found a Philco 16B Tombstone
Tom - yes, if it has that escutcheon, then it should have black rosettes. (I think.) Icon_crazy
Don found a Philco 16B Tombstone - by Ronin61 - 01-29-2014, 05:09 PM
RE: Don found a Philco 16B Tombstone - by morzh - 01-29-2014, 05:48 PM
RE: Don found a Philco 16B Tombstone - by Ronin61 - 01-29-2014, 09:20 PM
RE: Don found a Philco 16B Tombstone - by morzh - 01-29-2014, 11:17 PM
RE: Don found a Philco 16B Tombstone - by Ronin61 - 01-31-2014, 04:38 PM
RE: Don found a Philco 16B Tombstone - by Ron Ramirez - 01-31-2014, 06:36 PM
RE: Don found a Philco 16B Tombstone - by Ronin61 - 02-04-2014, 01:21 AM
Philco 91 Tuning Condenser
There are currently 10067 online users. [Complete List]
» 1 Member(s) | 10066 Guest(s)
