37-620 BC Reception Issue
Hi
Like Brenda said missing tube shields especially the first AF or the IF tubes. Also the cap in the agc curcuit or the cap in the IF tube screen grid bypass also the second filter cap or any of the other filter caps. In other words change out all caps. There are several caps that can cause your problem. Icon_biggrin My two cents
Joe
37-620 BC Reception Issue - by John_S - 01-30-2014, 06:14 PM
RE: 37-620 BC Reception Issue - by tab10672 - 01-30-2014, 07:57 PM
RE: 37-620 BC Reception Issue - by John_S - 01-31-2014, 12:48 PM
RE: 37-620 BC Reception Issue - by tab10672 - 01-31-2014, 02:17 PM
RE: 37-620 BC Reception Issue - by BrendaAnnD - 01-31-2014, 06:43 PM
RE: 37-620 BC Reception Issue - by w4rtc - 01-31-2014, 07:06 PM
RE: 37-620 BC Reception Issue - by John_S - 02-01-2014, 12:20 PM
RE: 37-620 BC Reception Issue - by BrendaAnnD - 02-01-2014, 05:07 PM
Philco 91 Tuning Condenser
