Actual picture of a 47-1230
Does anyone have an Actual picture of a OEM 47-1230? ( or I understand the 46-1209 and 46-1210 are identical). The Philco site seems to just have a drawing of it. Was hoping it would help me in determining how dark to make the different areas.
Actual picture of a 47-1230 - by Warren - 02-01-2014, 03:00 AM
RE: Actual picture of a 47-1230 - by Ron Ramirez - 02-01-2014, 09:43 AM
RE: Actual picture of a 47-1230 - by Ron Ramirez - 02-01-2014, 04:13 PM
RE: Actual picture of a 47-1230 - by Warren - 02-02-2014, 12:20 AM
RE: Actual picture of a 47-1230 - by Warren - 02-03-2014, 03:42 PM
Eico 232 VTVM Schematic
There are currently 8922 online users. [Complete List]
» 1 Member(s) | 8921 Guest(s)
