Philco 640 Cabinet Refinishing Chronicles
I want to do this right and got a little frustrated with some of the mistakes I made so I stepped away from it for awhile. Plus, things have gotten really busy at work so I really haven't had the time. No matter. I'll be diving back into it again within the next few months and will post updates. Thanks for showing an interest.
- Geoff
RE: Philco 640 Cabinet Refinishing Chronicles - by Geoff - 02-01-2014, 04:28 AM
Users browsing this thread: 47 Guest(s)
Philco 91 Tuning Condenser
There are currently 10134 online users. [Complete List]
» 2 Member(s) | 10132 Guest(s)
