Actual picture of a 47-1230
Yes, the Gallery only has an illustration...because no one has ever offered a photo of a 47-1230 for use in the Gallery. I've done all that I can do. Sorry I can't help you this time.
Actual picture of a 47-1230 - by Warren - 02-01-2014, 03:00 AM
RE: Actual picture of a 47-1230 - by Ron Ramirez - 02-01-2014, 09:43 AM
RE: Actual picture of a 47-1230 - by Ron Ramirez - 02-01-2014, 04:13 PM
RE: Actual picture of a 47-1230 - by Warren - 02-02-2014, 12:20 AM
RE: Actual picture of a 47-1230 - by Warren - 02-03-2014, 03:42 PM
Philco 91 Tuning Condenser
There are currently 7487 online users. [Complete List]
» 2 Member(s) | 7485 Guest(s)
