37-620 BC Reception Issue
Brenda,
That's a good idea on the shields. I will try to find some for this model. Another question on this model is the antenna setup, is it better to try a loop antenna like the one Philco suggests, or just use a single ended one?
Thanks
37-620 BC Reception Issue - by John_S - 01-30-2014, 06:14 PM
RE: 37-620 BC Reception Issue - by tab10672 - 01-30-2014, 07:57 PM
RE: 37-620 BC Reception Issue - by John_S - 01-31-2014, 12:48 PM
RE: 37-620 BC Reception Issue - by tab10672 - 01-31-2014, 02:17 PM
RE: 37-620 BC Reception Issue - by BrendaAnnD - 01-31-2014, 06:43 PM
RE: 37-620 BC Reception Issue - by w4rtc - 01-31-2014, 07:06 PM
RE: 37-620 BC Reception Issue - by John_S - 02-01-2014, 12:20 PM
RE: 37-620 BC Reception Issue - by BrendaAnnD - 02-01-2014, 05:07 PM
