Need a decent schematic Scott Laureate
Mondial: I think the newer generation of teenage techies have shifted over to computers. The older generation were electronic hobbyists but now they are the young internet/LINUX/software people. One of my sons like that. He has some interest in electronics but much more with LINUX, web pages, hacking etc... Much more readily available, cheaper etc... than the stuff I used to do at his age.
Herb S
RE: Need a decent schematic Scott Laureate - by hsusmann - 02-01-2014, 02:28 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
