20B escutcheon
Yes, the "philco" is smaller and the horse shoe design at bottom center is larger and more open. I wonder if the bezel in the original picture was a concept design.
20B escutcheon - by tab10672 - 02-01-2014, 03:38 PM
RE: 20B escutcheon - by Ron Ramirez - 02-01-2014, 03:45 PM
RE: 20B escutcheon - by tab10672 - 02-01-2014, 04:02 PM
RE: 20B escutcheon - by Ron Ramirez - 02-01-2014, 04:09 PM
Philco 91 Tuning Condenser
There are currently 9428 online users. [Complete List]
» 1 Member(s) | 9427 Guest(s)
