  • 1 Vote(s) - 5 Average
Philco 45 Butterfly Restoration Chronicles....Finished
Well the glue finally dried and I removed the planer and the table. It came out nice and flat, thank gosh!
Sanded it down, replaced the missing veneer I didn't have, then added the decorative raised veneer. Then I cut out the vent holes in the new top veneer and done for the day
Now it is again a waiting game:
RE: Philco 45 Butterfly Restoration Chronicles.... - by OldRestorer - 02-01-2014, 07:25 PM
Philco 91 Tuning Condenser
