  • 1 Vote(s) - 5 Average
Philco 45 Butterfly Restoration Chronicles....Finished
Looks great, im glad to see someone besides myself that would save a cabinet in such bad shape rather than trash it.
RE: Philco 45 Butterfly Restoration Chronicles.... - by tab10672 - 02-01-2014, 07:44 PM
Philco 91 Tuning Condenser
There are currently 9374 online users. [Complete List]
» 1 Member(s) | 9373 Guest(s)
