Philco 620B alignment woes
Bill, just align the lighted pointer, with the first line of the bottom edge of the scale. Another words, the first line after the last freq indicator dot for lack of a better word. Here's another thing I've learned. My 650X wasn't aligning up originally as I liked. I "tweaked" the dial scale just a hair, and the alignment went very smooth. I've had to do that on several sets in the past. A little fudging can go a long way Icon_wink Anyhow, that's where I would start.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Philco 620B alignment woes - by wonderwrench - 06-19-2008, 06:29 PM
[No subject] - by wonderwrench - 06-20-2008, 07:02 PM
[No subject] - by BDM - 06-20-2008, 07:19 PM
[No subject] - by wonderwrench - 06-20-2008, 07:46 PM
[No subject] - by BDM - 06-20-2008, 07:58 PM
[No subject] - by wonderwrench - 06-20-2008, 08:03 PM
[No subject] - by wonderwrench - 06-21-2008, 11:52 AM
[No subject] - by BDM - 06-21-2008, 12:24 PM
[No subject] - by wonderwrench - 06-21-2008, 12:51 PM
[No subject] - by BDM - 06-21-2008, 01:16 PM
[No subject] - by rghines1 - 06-21-2008, 01:33 PM
[No subject] - by BDM - 06-21-2008, 11:56 PM
[No subject] - by wonderwrench - 06-23-2008, 03:26 PM
[No subject] - by wonderwrench - 06-23-2008, 04:03 PM
[No subject] - by etech - 06-23-2008, 06:33 PM
[No subject] - by wonderwrench - 06-29-2008, 06:23 PM
[No subject] - by wonderwrench - 07-06-2008, 12:26 PM
[No subject] - by Ron Ramirez - 07-06-2008, 02:46 PM
There are currently 10586 online users. [Complete List]
» 2 Member(s) | 10584 Guest(s)
