Threads: 10
City: Columbia, SC
Perfect, thanks!
Yes it is. I don't remember the part number, but it matches the one on the 'evolution of model 89' page here. Those schematics all show the .35M part. I was surprised as well. I'll put in the 100k.
As always, thanks for all the invaluable help!
RE: Model 89 Cathedral - by skyscraper - 02-01-2014, 11:50 PM
Users browsing this thread: 39 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10604 online users. [Complete List] » 3 Member(s) | 10601 Guest(s)
