  • 1 Vote(s) - 2 Average
1936 Philco 645
That wire which passed through the terminal but was not soldered was actually a very small capacitor. It is sometimes known as a "gimmick" cap.
Evidently the Philco engineers found that the radio worked better with a small amount of capacitance between the two tuning stators and added the wire to provide that very small value.
Most likely it will not make a big difference, but you may want to reinstall the wire through the terminal as it came originally.
1936 Philco 645 - by Ronin61 - 03-23-2013, 10:33 PM
RE: 1936 Philco 645 - by morzh - 03-23-2013, 11:48 PM
RE: 1936 Philco 645 - by 7estatdef - 03-24-2013, 08:58 AM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 11:05 AM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 02:21 PM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 02:38 PM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 02:39 PM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 02:41 PM
RE: 1936 Philco 645 - by 7estatdef - 03-24-2013, 04:06 PM
RE: 1936 Philco 645 - by Ronin61 - 03-26-2013, 04:13 PM
RE: 1936 Philco 645 - by 7estatdef - 03-27-2013, 08:38 AM
RE: 1936 Philco 645 - by morzh - 03-27-2013, 12:15 PM
RE: 1936 Philco 645 - by codefox1 - 03-28-2013, 04:34 AM
RE: 1936 Philco 645 - by Ronin61 - 04-07-2013, 09:30 PM
RE: 1936 Philco 645 - by 7estatdef - 04-10-2013, 06:27 PM
RE: 1936 Philco 645 - by Ronin61 - 04-11-2013, 04:58 PM
RE: 1936 Philco 645 - by Ronin61 - 04-22-2013, 10:57 AM
RE: 1936 Philco 645 - by 7estatdef - 04-22-2013, 05:13 PM
RE: 1936 Philco 645 - by Winky Dink - 02-02-2014, 05:57 PM
RE: 1936 Philco 645 - by Mondial - 02-02-2014, 06:15 PM
RE: 1936 Philco 645 - by Winky Dink - 02-02-2014, 06:32 PM
RE: 1936 Philco 645 - by Winky Dink - 02-02-2014, 11:20 PM
RE: 1936 Philco 645 - by Mondial - 02-03-2014, 01:07 AM
RE: 1936 Philco 645 - by Winky Dink - 02-03-2014, 03:43 AM
RE: 1936 Philco 645 - by Mondial - 02-03-2014, 09:24 AM
RE: 1936 Philco 645 - by Ron Ramirez - 02-03-2014, 11:27 AM
RE: 1936 Philco 645 - by Winky Dink - 02-03-2014, 07:35 PM
RE: 1936 Philco 645 - by Winky Dink - 02-04-2014, 01:00 AM
RE: 1936 Philco 645 - by Winky Dink - 03-24-2014, 10:10 AM
RE: 1936 Philco 645 - by codefox1 - 03-24-2014, 10:52 AM
RE: 1936 Philco 645 - by Winky Dink - 03-24-2014, 11:41 AM
