hey guys
working on a 38-62 nos http://www.nostalgiaair.org/PagesByMode ... 013211.pdf
I don't have a .006 can I use .068 or .1 ?
also a .25 can I safely drop to .22
thanks sam
caps - by sam - 02-02-2014, 09:21 PM
RE: caps - by morzh - 02-02-2014, 09:26 PM
RE: caps - by morzh - 02-02-2014, 09:30 PM
RE: caps - by sam - 02-02-2014, 09:47 PM
RE: caps - by murf - 02-02-2014, 10:04 PM
RE: caps - by morzh - 02-02-2014, 10:09 PM
There are currently 9184 online users. [Complete List]
» 2 Member(s) | 9182 Guest(s)
