Sam
Have you noticed that the difference between 0.006 and 0.068 is an order of magnitude (11 times)?
And between 0.006 and 0.1 is 17 times?
You can't do that.
Now yes, you usually can safely replace .25 with .22. Provided they both are in the same units.
caps - by sam - 02-02-2014, 09:21 PM
RE: caps - by morzh - 02-02-2014, 09:26 PM
RE: caps - by morzh - 02-02-2014, 09:30 PM
RE: caps - by sam - 02-02-2014, 09:47 PM
RE: caps - by murf - 02-02-2014, 10:04 PM
RE: caps - by morzh - 02-02-2014, 10:09 PM
Philco 91 Tuning Condenser
There are currently 7843 online users. [Complete List]
» 2 Member(s) | 7841 Guest(s)
